think il get myself a set aswell then. What sidelights did you end up going for?
these ones LINK
the HID's come from the same seller
H7 and then pick your colour the lower the number the more white they are.
Click my car below as i have used both 8k and 6k but if i ever change will go lower.
H7 is for dipped only, no real need or the hids in high beam.
H1 is the high beam bulb.
I would recommend a kit from Hids4U (2yr warranty, good quality product and personal service) and would get the reduced length set just to make sure that the bulb doesn't hit the glare guard.
Plus as above you have the melting potential of the 55's.../QUOTE]
Borlicks...
Just had my 55W's delivered
Ah well, will fit them anyway and if they do melt, ill get some projectors or angel eyes![]()
Leave the guards in the standard headlight helps to stop he glare to other motorists.Hello,
I have an aftermarket HID xenon on my car, but I have a small problem: on the installation guide it was specified to remove the "glare guard", but I didn't do it. The bulb doesn't hit the glare guard. Can anyone explain what the "glare guards" do? What is their role? And which is best, to remove or not to remove them? Thank you.
Borlicks...
They should be fine, i think, people use 100/80 bulbs and they don't melt them.
Thank you for your answer. I made the right choice then. Tnx again.
) for a 2 hour drive! Pulled up when I got home and left them on, the lenses still felt cold, so doubt they will melt...
