Suitable?
I purchased this HID Kit and fitted it last Saturday. Worked perfectly but yesterday my Driver Side came on, faded and was off by the time I got home. Turned the lights off and on again and it worked.
Today it didn't work at all. Swapped the ballasts over and the driver side worked so it's not the bulb.
Already sorting a replacement ballast but is this a deeper issue?
Method: I can't post pics (sorry) but for the Driver Side there a hole in the black metal trim at the front of the engine bay near the headlight. There is an awkward lip on the trim though but I just chocked this with some 10mm foam pvc and bolted the ballast through the hole and foam. My passenger side is inside the black casing you have to remove before you can get to the case where the lights are. Just bolted this into the left section. Was purpose-built for a ballast. Haha.
