MK2 Leon Tdi FR...are the dipped beams H7 fitment?
dannychapman10
K04 Time ;)
Mar 30, 2009
1,268
Grimsby, UK
What do you mean by the CAN BUS system? He does not have auto lights on his Leon so does this effect that?
No, you still need ones to work with CAN-BUS, the Leon wiring systems as Jon mentioned above :) It will give you a bulb error message and then cut the power to the lights otherwise.
Danny.
ross27
Mazda 3 MPS
Mar 22, 2009
363
Glasgow
Just to add, ive got H7R HID kit, non CAN BUS, and ive never had a problem with the bulb out.
And i know alot of people on here can report the same.
Best bet to go for a Can Bus set.
Oct 17, 2006
2,141
Mid Wales
I think it'll come down to whether you have the bluetooth system or not.
If you have bluetooth and therefore the large MFD then you will have bulb monitoring - if not, then not.
ben-ducky
176
Llanelli, S Wales
Having bought the CAN BUS compatible HIDs and fitted them along with new white side light bulbs my mate is now getting a light on the dash as some of you mentioned? He thinks the side light bulbs are causing it though because it only comes on when only the sidelights are on but then goes off once the dipped beams are switched on?
Is he right in thinking this?
Are there different side lights available that dont throw up these errors.
Thanks in advance
Wayno321
yeah go all the way and get some HID's there so much better and only £70 off frebay
