Yup thanks for the tests lee m8
If it was a little clearer before "ie more posts with explanations lol" would of known my CTS was ok but least its a new shiny one now
Ok here is the outcome of the tests I have done!
My issue was that every time I turned my engine off and then got back in and started her up my needle was allot higher than my CTS reading from my CC unit. So i did some tests.
Short journeys:
Even with your needle and CTS saying 90s if you switch your engine off "even for short amount of time say 10 mins" The CTS will prob start around 30 and climb back up were as your needle will still prob say 90 or be allot higher! this is fine! "so it seems"
Longer Journeys:
If you drive miles over 30 "this was my test" to get it warmed up proper you could turn your car off/on and it will read 90s on both."well should" 30 mins later and the CTS will still read high values like 60s and your needle most likely would show around 90s, the CTS will climb back up once again.
The needle seems to take longer to go down, you could leave you car 30 mins + and chances are it would be close to or strait back to 90. However you CTS on your CC display will most likely show less than your needle. If you leave you car upto 1hr the CTS would prob start around 40 this all depends on how hot you car is/was. The longer the journey the hotter it will become and the CTS will read high values when switched on/off for a period of time.
I do mostly short journeys so my CTS was always reading 30-40 each time I stop even if it was for 10 mins. After my tests and asking lee to make a couple himself I'm convinced this is indeed normal. So be careful before you go out and by a new CTS like me lol.
My TIPS:
The CTS reading "on the CC" should climb to 90c as should your needle from cold.
From cold If your needle does not beat your CTS/CC to temperature you prob need a new thermostat as my CTS never beets the needle "from cold". Specially now I have a new thermostat its so much faster to get to 90s.
If driving and the CTS says 90 and you see your needle move down then up again this prob means you need a new thermostat.
Hope this helps others.
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
If you can understand it lol
