yes another vagcom noobie
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
Bobby.Gee
Leon Cupra R 210
Jan 2, 2010
271
ive got this and the software...
Is there anyway of getting the full software? And any benefit.
I would like to test my MAF does anyone know how i can do that?
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
maf is block 003
benefits of full license are huge mate, full logging capability, and all features available
Bobby.Gee
Leon Cupra R 210
Jan 2, 2010
271
what do you mean block 003?
im a complete newbie with this mate.. Sorry i should probably read on the vagcom bit, is there a way of telling if my D/V is leaking by it?
james walker
May 24, 2007
5,121
retford notts
not via maf readings.
you want to log boost for that really, actual vs requested.
all vagcom sections are in blocks...
hook it up and have a look round the software mate, pretty self explanitory
you want engine01
measuring blocks08
then input the block you want to measure
usual blocks are 003, which is maf reading
log these together, 2 or 3 blocks at a time, have a look in vagcom section for which is best to log together or this link will help you
http://dieselinside.com/howto/vagcom/log_18t.htm
115 will give you boost, actual vs requested, this will tell you if you have a leak, as actual will be down on requested
020 will give you correction factors or timing pull... ideally these should be 0, but upto 6 is acceptible
118 gives intake temps
031 gives lambda values
when you do a run, start it at 2500k revs and log to the redline ideally in 4th, but 3rd is more practical
chrisp123
hi all.
i just bought this cable from ebay
http://cgi.ebay.co.uk/VAG-COM-USB-DIAGNOSTIC-CABLE-409-1-OBD2-II-LEAD-VAG-COM_W0QQitemZ330399696070QQcmdZViewItemQQptZUK_Diagnostic_Tools_Equipment?hash=item4ced5b44c6
now can any one tell me the software i need to down load from ross tech,
im unsure what one to download. im running lcr 210
also i will in the future buy the full version, can i use this current cable?
thanks all
From your link the Vag com software is supplied! If not its 409.1 version for non ross tech cables
I have one of these cables but can only get it to work on windows XP not Vista or 7
chris
LukeK
410
Preston lancashire
you want engine01
measuring blocks08
Can you do all that with the lite version? You just have to log onto the first section?
