anti lag system?
sheffboy
avoiding potholes
May 25, 2007
655
yes please.
can you imagine the look of the spotty youth behind you in his chaved up corsa :cartman:
h7 cya
453
I think it allows the turbo to be spooling even at idle by leaving the throttle open a little. kills the turbo unless you spend a lot of money on a maram shafted turbo, sounds the nuts tho.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
All the Super Copa ECU's had this capability, but it was not enabled on UK cars (noise regs maybe?)
No point though, weeny K04 running fairly low boost for 250bhp, so no lag to be anti.
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
Ah, i see what you mean. I've only ever seen anti lag on rally cars, or the odd track cars ie big power cossies and supras, evo's, impreza's etc
sheffboy
avoiding potholes
May 25, 2007
655
kill joy :p
keenocupra
81
stirling
anti lag is built into the map of ur car its all to do with timing and fuel to allow boost to build when stationary and revved to a seperate system rev limiter.
SHAME IT KILLS TURBOS THO :(:(:(
Dec 31, 2007
1,479
Reading
Forgive the noob question, but is this like a turbo timer? Keeps the turbo spinning so you can drop the clutch and don't have to wait for the turbo to spool up?
Nick-21
121
No a turbo timer is for when you switch the car off, it leaves the car running for a while to let it cool down.
Anti lag keeps the turbo spooled up when you're changing gears hence gets rid of the lag, does this by injecting fuel which goes bang in the exhaust hence the cool noise and flames.
Basically its cool!
http://www.youtube.com/watch?v=WTAPpsL2xOU
