Like many said, most would have the LCR anyday but if costs are an issue then the FR would also be a good drivers car and is easily tweakable!
No arguing or anything intended but I fail to see how a mapped FR or vRS with close to 300lb/ft of torque wouldn't be as quick as a standard LCR from say 30-90 through the gears... simple maths and power to weight ratios suggest that one would be.
My Missus has a GT TDi PD150 Golf mk4 which has the same engine and through the gears it is as quick as my LCR from say 30-90 no doubt about it. Okay the power delivery is different, but they are both rapid in real world terms. I'm sure if I mapped the Golf it would be quicker than my standard LCR, although the LCR would be much easier to keep 'on the boil' due to its wider power band.
As far as 'leaving Octavias or vRSs for dead' - that is something that you just can't prove unless you're both on the strip at Santa Pod both gunning it. On a public road there are so many variables and you have no idea if the Octavia was giving it 100% when you pulled away
Anyway, can we have some pics of the new LCR matey?!
J
J
