8v gti gearbox's
redlinemike
Choo Choo MF
Dec 21, 2008
37
Frozen North, Just of the M8
hi guys, just been out in the snow & blown reverse gear out on my 99 8v gti :cry::cry::censored::censored:, are the gearboxes specific to this car or do other boxes fit?
Please help & point me in the right direction
Mike
Sep 20, 2006
756
Birmingham
Other VWs had the same box. I think its a 02A box (sure someone will confirm/correct me soon). Just need to find one and swap over.
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
weren't 8vs O2Os? rod change, id think any vw 8v would be a swop, albeit slightly different ratios, im thinking mk2/mk3 golfs as obvious donors.
get new drive shaft bolts, you'll probably need them when changing box's
redlinemike
Choo Choo MF
Dec 21, 2008
37
all sorted now, got a box out of a golf gti, found the input shaft had less splines (24 instead of 28) & was 2mm smaller in diam, but its all back together now with a new clutch & the clutch is feather light & i think the ratios might be slightly lower as its much quicker through the gears,
