Basically any 085 gearbox, numbers are the code for the case shape/clutch size & the 3 letter code is the ratio. Check things like clutch cable mounts and gear selector shafts though as they do differ between cars, eg some 085 boxes from Polos will fit the bell housing but the selector shaft won't match your gearchange. (the voice of bitter experience)
Other than that, the search function is your friend, there's loads of info about this, including why the 085 design is such a crappy box...
