Monkeytibs do you have a cupra or a cupra r?
The normal cupra TIP is a bit of a pain to fit, its very tricky getting it on the turbo past the metal water pipe......not complicated just a pain.
HIDs arrived today, going to fit them tomorrow if it's not too disgustingly icy. Looks simple as hell, just going to be careful drilling the back of the lights. Anyone got pictures of where they but the ballasts?
i fitted mine last weekend an strapped a ballast to the washer bottle on drivers side and on the passenger side just stuck it to the tray under the light unit ull see the tray when you take off the cover. make no end of diff. :D
erm 3m tape then cabled tied it to the washer bottle an just tape on2 the tray as the ballast hasn't got anywhere to go. the 3m tapes ridiculously strong tape :D ill try an get a picture
That's a good shout actually, I've got some velcro lying around somewhere from when I fitted pressed plates to me old polo. I want to go fit them now but everytime I step outside I go flying on the ice :(
Velcro is better than double side tape because you can remove and refit the ballests if you need to work on anything :)
My drivers side is under headlight my pass side is on battery cover.
I was just using some heavy duty velcro from Halfrauds for my plates and never had a problem with it. My brother's got the car now and they've been on there over a year now!
I'm hearing the words velcro, cable ties and 3m tape alot with these HID fits. Has anyone actually fitted them properly? ;-)
