Ibiza ko3s Poor Performance
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
stock map returned, not faulty code but car not run fine
same boost deviation code?
post logs of block 115
stock boost is unlikely to trip +ve deviation
checked your pipes?
you said you adjusted actuator... which way? and why?
tarzan
cupra owner from norway
Mar 15, 2008
1,122
drammen norway
mine was mapped and wastegate was adjusted.adjusted it back to fine out that the map was poor so now i have revo stage 2 and works really good:D
g-max
35
I do not know English well, I hope you understand me correctly. when the car is in original file did not go well. When load a custom file all is OK but for a specified time 100-150km and then again 17963. I think ecu is broken.
If someone wants to send his file which drive to see if it is done correctly.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
files aint free here sir
deviation code is probably a deviation... do you have any vagcom logs you can post up of block 115?
g-max
35
I will send a file. I did not write correctly. Tomorow post result from block 115
g-max
35
Friday,08,January,2010,13:58:37
6K0 906 032 AA,,1.8L 20VT EU3 0002,
,Group A:,'115,,,,Group B:, Not Running,,,,Group C:, Not Running
,,RPM,Load,Absolute Pres.,Absolute Pres.,,,,,,,,,,
,TIME,,,,,TIME,,,,,TIME,,,,
Marker,STAMP, /min, %, mbar, mbar,STAMP,,,,,STAMP,,,,
,0.00,1400,33.1, 1010.0,1030.0,,,,,,,,,,
,0.30,1480,33.8, 1010.0,1030.0,,,,,,,,,,
,0.60,1600,34.6, 1010.0,1030.0,,,,,,,,,,
,0.90,1680,37.6, 1010.0,1030.0,,,,,,,,,,
,1.20,1840,47.4, 1010.0,1030.0,,,,,,,,,,
,1.50,2120,74.4, 1180.0,1030.0,,,,,,,,,,
,1.80,2480,85.7, 1160.0,1160.0,,,,,,,,,,
,2.10,2920,94.0, 1460.0,1320.0,,,,,,,,,,
,2.40,3480,133.1, 1920.0,1540.0,,,,,,,,,,
,2.71,4440,136.1, 1910.0,1690.0,,,,,,,,,,
,3.01,5280,148.1, 1870.0,1760.0,,,,,,,,,,
,3.31,5760,139.8, 1860.0,1750.0,,,,,,,,,,
,3.61,6040,136.1, 1800.0,1660.0,,,,,,,,,,
,3.91,6400,103.0, 1010.0,1530.0,,,,,,,,,,
,4.21,5640,10.5, 1010.0,1320.0,,,,,,,,,,
,4.51,4280,85.7, 1980.0,1040.0,,,,,,,,,,
,4.81,4120,132.3, 2000.0,1610.0,,,,,,,,,,
,5.11,4400,138.3, 1980.0,1660.0,,,,,,,,,,
,5.41,4680,156.4, 1950.0,1890.0,,,,,,,,,,
,5.71,4960,154.9, 1920.0,1860.0,,,,,,,,,,
,6.01,5240,151.9, 1910.0,1840.0,,,,,,,,,,
,6.31,5480,147.4, 1910.0,1840.0,,,,,,,,,,
,6.61,5720,145.1, 1910.0,1800.0,,,,,,,,,,
,6.91,5920,141.4, 1860.0,1770.0,,,,,,,,,,
,7.21,6160,136.8, 1810.0,1730.0,,,,,,,,,,
,7.51,5960,18.0, 1010.0,1660.0,,,,,,,,,,
,7.81,5360,8.3, 1010.0,1190.0,,,,,,,,,,
,8.10,4160,103.8, 1990.0,1130.0,,,,,,,,,,
,8.41,4320,128.6, 1970.0,1700.0,,,,,,,,,,
,8.71,4440,145.1, 1960.0,1720.0,,,,,,,,,,
,9.00,4600,153.4, 1950.0,1920.0,,,,,,,,,,
,9.31,4680,155.6, 1940.0,1890.0,,,,,,,,,,
,9.61,4840,157.1, 1930.0,1920.0,,,,,,,,,,
,9.91,4960,156.4, 1910.0,1910.0,,,,,,,,,,
,10.21,5080,154.9, 1900.0,1890.0,,,,,,,,,,
,10.51,5160,152.6, 1900.0,1860.0,,,,,,,,,,
,10.81,5280,150.4, 1910.0,1860.0,,,,,,,,,,
,11.11,5400,149.6, 1910.0,1860.0,,,,,,,,,,
,11.41,5480,148.1, 1920.0,1880.0,,,,,,,,,,
,11.71,5560,147.4, 1920.0,1870.0,,,,,,,,,,
,12.01,5680,147.4, 1930.0,1870.0,,,,,,,,,,
,12.31,5760,146.6, 1920.0,1850.0,,,,,,,,,,
,12.61,5840,144.4, 1900.0,1850.0,,,,,,,,,,
,12.91,5920,142.1, 1300.0,1840.0,,,,,,,,,,
,13.21,5760,16.5, 1010.0,1470.0,,,,,,,,,,
,13.51,4880,64.7, 1830.0,1070.0,,,,,,,,,,
,13.80,4680,133.1, 1850.0,1560.0,,,,,,,,,,
,14.11,4720,131.6, 1850.0,1610.0,,,,,,,,,,
,14.41,4800,148.1, 1840.0,1800.0,,,,,,,,,,
,14.70,4840,146.6, 1840.0,1810.0,,,,,,,,,,
,15.00,4880,151.1, 1830.0,1830.0,,,,,,,,,,
,15.30,4960,152.6, 1830.0,1850.0,,,,,,,,,,
,15.60,5040,149.6, 1830.0,1840.0,,,,,,,,,,
,15.90,5080,149.6, 1830.0,1820.0,,,,,,,,,,
,16.20,5120,148.9, 1830.0,1820.0,,,,,,,,,,
,16.50,5160,148.1, 1840.0,1810.0,,,,,,,,,,
,16.80,5240,148.1, 1840.0,1810.0,,,,,,,,,,
,17.10,5280,146.6, 1840.0,1820.0,,,,,,,,,,
,17.40,5320,147.4, 1840.0,1830.0,,,,,,,,,,
,17.70,5360,147.4, 1840.0,1810.0,,,,,,,,,,
,18.00,5400,145.1, 1840.0,1830.0,,,,,,,,,,
,18.30,5480,145.9, 1840.0,1810.0,,,,,,,,,,
,18.60,5520,145.1, 1850.0,1820.0,,,,,,,,,,
,18.90,5480,25.6, 1010.0,1760.0,,,,,,,,,,
,19.20,4960,9.8, 1010.0,1220.0,,,,,,,,,,
,19.50,4480,110.5, 1890.0,1220.0,,,,,,,,,,
,19.80,4480,128.6, 1890.0,1730.0,,,,,,,,,,
,20.10,4520,143.6, 1880.0,1700.0,,,,,,,,,,
,20.40,4560,149.6, 1880.0,1910.0,,,,,,,,,,
,20.70,4600,151.9, 1870.0,1880.0,,,,,,,,,,
,20.99,4600,156.4, 1870.0,1920.0,,,,,,,,,,
,21.30,4640,155.6, 1800.0,1930.0,,,,,,,,,,
,21.60,4760,30.1, 1010.0,1520.0,,,,,,,,,,
,21.90,4600,9.8, 1010.0,1190.0,,,,,,,,,,
,22.20,4560,6.8, 1010.0,1120.0,,,,,,,,,,
,22.50,4560,8.3, 1010.0,1080.0,,,,,,,,,,
,22.79,4520,8.3, 1010.0,1070.0,,,,,,,,,,
,48.28,1520,54.9, 1010.0,1050.0,,,,,,,,,,
,48.58,1640,78.9, 1450.0,1080.0,,,,,,,,,,
,48.88,1800,89.5, 1560.0,1160.0,,,,,,,,,,
,49.18,1960,97.7, 1640.0,1270.0,,,,,,,,,,
,49.48,2160,111.3, 1920.0,1410.0,,,,,,,,,,
,49.78,2400,128.6, 1930.0,1600.0,,,,,,,,,,
,50.08,2640,145.1, 1920.0,1830.0,,,,,,,,,,
,50.38,2960,153.4, 1920.0,1940.0,,,,,,,,,,
,50.69,3280,157.1, 1900.0,1960.0,,,,,,,,,,
,50.98,3560,151.9, 1890.0,1920.0,,,,,,,,,,
,51.29,3840,149.6, 1900.0,1840.0,,,,,,,,,,
,51.59,4160,151.9, 1900.0,1870.0,,,,,,,,,,
,51.89,4440,152.6, 1870.0,1850.0,,,,,,,,,,
,52.19,4720,151.9, 1850.0,1810.0,,,,,,,,,,
,52.49,5000,151.1, 1830.0,1790.0,,,,,,,,,,
,52.79,5240,147.4, 1830.0,1790.0,,,,,,,,,,
,53.09,5480,143.6, 1840.0,1770.0,,,,,,,,,,
,53.39,5720,112.8, 1010.0,1640.0,,,,,,,,,,
,53.69,5200,10.5, 1010.0,1310.0,,,,,,,,,,
,53.99,4320,29.3, 1870.0,1100.0,,,,,,,,,,
,54.28,3880,120.3, 2010.0,1380.0,,,,,,,,,,
,54.59,4000,127.1, 2000.0,1640.0,,,,,,,,,,
,54.89,4120,149.6, 1990.0,1840.0,,,,,,,,,,
,55.19,4240,152.6, 1970.0,1940.0,,,,,,,,,,
,55.49,4400,159.4, 1960.0,1970.0,,,,,,,,,,
,55.79,4520,160.2, 1950.0,1980.0,,,,,,,,,,
,56.09,4640,160.2, 1940.0,1950.0,,,,,,,,,,
,56.39,4760,157.9, 1910.0,1930.0,,,,,,,,,,
,56.69,4880,155.6, 1900.0,1890.0,,,,,,,,,,
,56.98,4960,154.9, 1900.0,1870.0,,,,,,,,,,
,57.28,5080,153.4, 1890.0,1860.0,,,,,,,,,,
,57.58,5200,151.9, 1900.0,1840.0,,,,,,,,,,
,57.88,5280,148.9, 1900.0,1840.0,,,,,,,,,,
,58.18,5400,148.1, 1910.0,1850.0,,,,,,,,,,
,58.48,5480,148.9, 1910.0,1850.0,,,,,,,,,,
,58.78,5560,146.6, 1910.0,1860.0,,,,,,,,,,
,59.08,5680,124.1, 1010.0,1810.0,,,,,,,,,,
,59.38,5240,12.8, 1010.0,1360.0,,,,,,,,,,
,59.68,4400,90.2, 1860.0,1060.0,,,,,,,,,,
,59.98,4480,133.1, 1860.0,1700.0,,,,,,,,,,
,60.28,4520,131.6, 1860.0,1580.0,,,,,,,,,,
,60.58,4560,146.6, 1860.0,1840.0,,,,,,,,,,
,60.88,4600,144.4, 1850.0,1750.0,,,,,,,,,,
,61.18,4680,150.4, 1850.0,1870.0,,,,,,,,,,
,61.48,4720,151.1, 1840.0,1860.0,,,,,,,,,,
,61.78,4760,150.4, 1840.0,1850.0,,,,,,,,,,
,62.08,4840,151.1, 1820.0,1830.0,,,,,,,,,,
,62.38,4880,149.6, 1820.0,1840.0,,,,,,,,,,
,62.68,4920,148.9, 1810.0,1810.0,,,,,,,,,,
,62.98,5000,148.1, 1820.0,1810.0,,,,,,,,,,
,63.28,5040,147.4, 1820.0,1820.0,,,,,,,,,,
,63.58,5080,148.1, 1820.0,1810.0,,,,,,,,,,
,63.88,5120,148.9, 1820.0,1800.0,,,,,,,,,,
,64.18,5160,146.6, 1820.0,1810.0,,,,,,,,,,
,64.48,5200,145.9, 1830.0,1820.0,,,,,,,,,,
,64.78,5240,146.6, 1830.0,1800.0,,,,,,,,,,
,65.08,5280,144.4, 1840.0,1810.0,,,,,,,,,,
,65.38,5320,145.9, 1840.0,1820.0,,,,,,,,,,
,106.45,2320,47.4, 1010.0,1080.0,,,,,,,,,,
,106.75,2400,46.6, 1010.0,1090.0,,,,,,,,,,
,107.05,2480,59.4, 1010.0,1080.0,,,,,,,,,,
,107.35,2600,86.5, 1550.0,1140.0,,,,,,,,,,
,107.65,2760,115.8,1930.0,1400.0,,,,,,,,,,
,107.95,3040,133.1,1920.0,1700.0,,,,,,,,,,
,108.25,3320,152.6,1900.0,1820.0,,,,,,,,,,
,108.55,3640,148.9,1900.0,1870.0,,,,,,,,,,
,108.86,3960,154.9,1910.0,1900.0,,,,,,,,,,
,109.16,4200,154.9,1890.0,1910.0,,,,,,,,,,
,109.46,4560,157.1,1880.0,1860.0,,,,,,,,,,
,109.76,4760,154.9,1860.0,1840.0,,,,,,,,,,
,110.06,5040,153.4,1840.0,1810.0,,,,,,,,,,
,110.36,5280,148.1,1850.0,1800.0,,,,,,,,,,
,110.66,5560,142.9,1860.0,1780.0,,,,,,,,,,
,110.96,5760,142.9,1840.0,1760.0,,,,,,,,,,
,111.26,6000,124.8,1010.0,1750.0,,,,,,,,,,
,111.56,5480,12.0, 1010.0,1360.0,,,,,,,,,,
,111.86,4680,21.8, 1840.0,1120.0,,,,,,,,,,
,112.15,4120,123.3,2000.0,1410.0,,,,,,,,,,
,112.45,4200,127.8,1980.0,1670.0,,,,,,,,,,
,112.75,4360,154.1,1970.0,1830.0,,,,,,,,,,
,113.06,4480,150.4,1950.0,1870.0,,,,,,,,,,
,113.36,4600,157.9,1940.0,1900.0,,,,,,,,,,
,113.66,4720,158.6,1930.0,1930.0,,,,,,,,,,
,113.96,4840,157.9,1900.0,1910.0,,,,,,,,,,
,114.26,4960,155.6,1890.0,1880.0,,,,,,,,,,
,114.56,5080,154.1,1890.0,1850.0,,,,,,,,,,
,114.86,5200,151.1,1890.0,1850.0,,,,,,,,,,
,115.16,5280,149.6,1900.0,1830.0,,,,,,,,,,
,115.46,5400,148.1,1900.0,1850.0,,,,,,,,,,
,115.76,5480,148.9,1910.0,1850.0,,,,,,,,,,
,116.06,5600,145.9,1920.0,1850.0,,,,,,,,,,
,116.36,5680,145.1,1910.0,1850.0,,,,,,,,,,
,116.66,5800,145.1,1900.0,1860.0,,,,,,,,,,
,116.96,5880,145.1,1890.0,1840.0,,,,,,,,,,
,117.26,5960,142.1,1880.0,1840.0,,,,,,,,,,
,117.56,6040,141.4,1200.0,1840.0,,,,,,,,,,
,117.86,5840,15.0, 1010.0,1460.0,,,,,,,,,,
,118.16,4920,90.2, 1820.0,1060.0,,,,,,,,,,
,118.46,4800,130.8,1830.0,1670.0,,,,,,,,,,
,118.76,4840,136.1,1830.0,1620.0,,,,,,,,,,
,119.06,4880,146.6,1830.0,1810.0,,,,,,,,,,
,119.36,4960,149.6,1820.0,1810.0,,,,,,,,,,
,119.66,5000,151.1,1820.0,1840.0,,,,,,,,,,
,119.95,5080,143.6,1540.0,1840.0,,,,,,,,,,
,120.25,5000,24.8,1010.0,1420.0,,,,,,,,,,
,120.54,5000,8.3,1010.0,1180.0,,,,,,,,,,
,120.84,4960,7.5,1010.0,1110.0,,,,,,,,,,
,121.15,4920,9.0,1010.0,1090.0,,,,,,,,,,
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
during this run it popped a +ve deviation boost fault code yea?
Code:
There's a 1bar boost request in here and 0.3bar actual
this your perfomance code or your standard? (its in between on boost levels)
g-max
35
when i reflashed with any new file from my big colection from all tunners for which i hear good feedback ,the car goes fine around 80-90km and then come back with smooth acceleration and have his problems with deviation.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
its not something sill ylike the map sensor playing up is it? have you tried another one maybe?
(clutching at straws now)
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Bill was talking about the map sensor. Its in your intercooler pipe work and detects the amount of boost being produced.
g-max
35
maf,map,sparkplug,coilpack,coolant temp sensor,lambda sensor,n75,hoses, turbo k03s. the result is the same 17963
