Just driving home my engine management light is now flashing and i have lost all power to the car
The car is booked in for Monday but going to try and take it tomorrow and get a car for the weekend.
The car has goine into limp home mode because you have not followed the correct regeneration process when tne DPF light came on!
The DPF light does not indicate a fault, it means you have to drive the vehicle at 40-50 mph in as high a gear possible with revs between 1600-1800 without stopping until the light goes off.
This is laid out in the user manual! Have a read!
If the engine light is not on, be prepared to pay for a forced regeneration if they do not find a sensor fault!
does anybody know where the G450 sensor is as i have the same problem as most, Exuast pressure sensor implausible signal. my 06 altea fr is just out of warranty and have had quite a large quote from seat to do this. got the vag com lead and software, will this be an easy fix?
