im on full tank on miles til empty (not that its accurate ) reckons im on coarse for 351miles is this becuse its used to shorter journeys and a lead footing
i tried the venting thing the other day filled it full then pressed that little button thingy and a little bit of air escaped , is that it i never then tried puting more in tho
I just fill up normally until the pump clicks off, then use the tip of the nozzle to hold the button down while continuing to fill (slowly!), I watch down the filler neck until I see the fuel rising up. A couple more presses/releases of the button usually see the fuel drop back down again.you do get an odd look at the pumps as you have the glove on the hand not holding the pump then you wedge the finger down to hold the button as you fill up.
Try not to let any diesel overflow or leak out, eventually it'll dribble down and drip off the car somewhere - and diesel on the road is bad news for motorcyclists...ye i filled to the brim was starting to pour out
It should improve as the engine gets more miles on it.Suppose I'm cheating a bit with a 70L tank, but I managed 615miles the other week out of the Exeo Average of 49.1mpg.
Most of that was motorway miles down to Devon and back, sat at 75-80 most of the way.
I suppose if I drove like a pansy then I could probably get 700+ without too much trouble
