Just thought id see if anyone had any ideas on the subject.
About three months ago the ABS & TC light flashed up on the dash, the next day it went and I didn't see it again for about 4 weeks.
Then it was off and on from day to day until it constantly stayed on.
I plugged in VAG COM and got the following:
Control Module Part Number: 1J0 907 379 AF
Component and/or Version: ASR 20 IE CAN 0001
Software Coding: 13404
Work Shop Code: WSC 00000
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
16-10 - Signal Outside Specifications - Intermittent
I checked the connections to the ABS unit, but the light still stayed on.
Managed to get a new ABS unit (pump and electronic section) which I fitted today.
But the ABS & TC lights still remain on, iv checked all the ABS & TC fuses and they all seem to be ok.
Just wondering if the ABS unit I fitted today needs any further setting up - I.E - coding to the ECU?
I haven't cleared the codes on VAG COM.
Also, although I pressure bled the brakes, is it necesary for the ABS system to be purged through VAG COM - as after I had finished fitting the new ABS unit and bled the brakes, the brake pedal is really spongy.
I know Danny_Lad had the same problem a few months ago, but not sure if he managed to sort it?
Any help appreciated,
Many Thanks.
1 Fault Found:
Many Thanks.
