Yes, one of the worst designs I've ever seen on an engine, the engine mount sitting inbetween the timing belt is just plain stupid! Tomorrow I should have the timing belt finished though.
The INA oil pan is also a source of much annoyance - first I had to trim one edge to get it to fit, then I had to modify the oil return line to get that to fit, NOW the dipstick won't go in, so I'll have to take it back off again to modify it to get that to fit - what a PITA!
At least the BDM sump went straight on with no hassles at all.
You can't shorten the dipstick - lol! I'll have to take the sump off again and enlarge the hole where the dipstick passes through the top plate of the baffle, it's obviously too small and/or not in the right place. You can see the hole on the left side of the plate in this pic:
Looks way too small to me. I'm going to take a 25mm holesaw to it.
Rob,
Is this not returnable now as its not fit for purpose? I know you can but surely all this work is not up to you to do. Fit the Backdraft one get your money back for this one??
Don't know guys, I've come this far with it, I'll take it off tomorrow and enlarge the hole, I'll put something on the tip of the dipstick to mark where it hits, we'll see how far out it is!
Good day today though - timing belt is done, alternator back on and new accessory belt is on, SEM manifold is back on, as are the injectors and fuel rail, coolant header tank is back on, spark plugs are in.
Not much to do now!
mine was out aswell i just ground the end of the dip in to a point
It'd be nice of you to feed back to INA how much you have to "adjust" the hole, it'd save everyone else grief.
Not much to do now!
