Wipers what to get?
Acksaw
Confused
Apr 25, 2009
289
Newcastle, Staffs
www.acksaw.com
Hey guys, I've finally got sick enough of the water smudge I get when it's raining, wipers go up and clear the window fine but when the one in front of the drivers seat comes back down, it smudges the water and makes it really hard to see.
I have a 52 1.2 S and as far as I know I can't have the aero wipers without the retrofit kit? I really don't know much about it so would like as much info on this, how hard it is to do, price etc.
One thing that I have noticed is I think the passenger side wiper arm is third party as there is a small piece of metal going through it that has gone rusty and isn't on the other one. Not sure if I can replace this wiper arm easily and cheaply?
Totally confused about which wipers to get and have search the forum but don't understand the replies!
These were the retro fit I was looking at but not sure if these fit mine:
http://www.autobulbsdirect.co.uk/AR533S-Bosch-Aerotwin-Retro-fit-Twin-Pack-21-19-530-475mm-19.html
These apparently fit but these are retrofit aero:
Front:
http://www.wiperblades.co.uk/bosch-...=546&Year=2002&Position=5&ID=39&Ref=prod-info
Rear (Not aero or retrofit):
http://www.wiperblades.co.uk/bosch-...k=546&Year=2002&Position=3&ID=5&Ref=prod-info
EDIT: Just remembered my rear wiper works great but makes an horrendous noise unless the window is absolutely soaked, doesn't seem smooth at all and on the initial wipe seems to jump a bit and not clean it very well, coming down it's fine.
mark1231
146
clean the screen with meths and the blades should get rid of the smudges ok
Ric 2001
Need an ID-ten-T form
Front:
Well the product from autobulbsdirect is the exact same product as the wiperblades website. They will both fit thats what I have on the cupra and they work great. Look good too.
Acksaw
Confused
Apr 25, 2009
289
Newcastle, Staffs
www.acksaw.com
Just an update, fronts came today and they totally transform the front of the car, look even better than I had hoped. Great purchase and great wiping! Just the read to put on when it comes (Ordered from a shop, the others from eBay, says a lot..)
andy17
PD100
May 20, 2009
416
Southport
Where they much cheaper on ebay? Any chance of a link? Might get some of these seen as its now winter..even though we seem to have missed summer
Cheers :)
andy17
PD100
May 20, 2009
416
Southport
Whilst where going onto rear wipers ;) How easy is it to change the rear one to a facelift/polo wiper?
It wont involve taking the boot trim off or anything will it? Im not mechanically minded at all. Will take me a few days to change the front ones :D
Acksaw
Confused
Apr 25, 2009
289
Newcastle, Staffs
www.acksaw.com
I'm wondering the same.
The wipers are dead easy to change though, you just pulled them up off the windscreen and angle them and then give them a pull. To put the new ones on, you will see there is an arm you pull up, this clamps over the bend in the wiper, it's difficult to explain how it goes on but I can give you a picture if need be.
For the rear arm - There's a plastic "cover" which you just clip off - you'll then need to undo a 14mm nut iirc and just give the whole thing a tug. You then line up the new Polo arm and give it a chap onto the splines and tighten the nut. The plastice cover they give you for the polo arm might need trimmed though or it will rub on the window.
hop2manual42
try ebay, i just got a set for 6.78 or something and 1.50 postage.
andy17
PD100
May 20, 2009
416
Southport
Sounds easy enough, will give it a go.
Front wipers came today just put them on. Also put in some Philips xtreme bulbs
NickyJam
FR - gone, not forgotten
Mar 17, 2008
1,669
SW LONDON
think I may have to get some soon rather than later the noise one of mine is making is really irritating even after I cleaned it! They have been on there 9 months and I do very very low mileage is this normal?!
mine don't make noise but after just a few months they started leaving strings as they wiped...think it was due to the grit they stuck on the roads this time last year which possibly stickes to the screen and cuts the bottom of the blades
FR_Simon
57
Surrey
I bought the WiperBlades own brand front blades for my 2007 FR and am pretty impressed, at half what Halfrauds wanted for their generic blades they are have been doing a good job for the last 2 months. Can't complain as yet although assume they wont last as long as the Bosch's.
