Where do I stand with dealership - faulty MAF
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
Hey guys
Went down to Performance Torque today to have stage 1 done, all fine and dandy but will mentioned that my MAF wasn't running right
He said when he unplugged it, it ran more power but lacked the torque. Ran VAG com on it and said it was running less than what the MAF should be, if thats right
You can feel it when driving that the boost is there but bit of a flat spot with torque.
But this was a MAF i replaced in May from SEAT, so a bit pee'd off I went down but didn't have my invoice and the guy said he can't do anything without an invoice.
Then a mechanic came out and I explained to him and he said it may not be the MAF technically he said it could be down on pressure from a leak somewhere.
Now just a few questions, is the mechanic talking rubbish?
Where do I stand with no invoice?
And then he said if I DID have an invoice they would test it to make sure it was faulty, if it was faulty they will replace it, if its not then I would have to pay for the work they have done!!!!!
I feel like i'm being screwed:wtf:
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Firstly he should have a record of the transaction hinmself so give him the info and approximate time of purchase and request a copy as i 'believe' they are meant to be saved for at least 5-10yrs or something alnog those line but be patient as it sound's like he is not the most helpful :(
the more info you have the easier it is to sort out like how did you pay ? check your credit card statements for a date ? etc
if you get no joy asking nicely then recorded post a request by letter to the dealer principal explaining your purchase and a request for invoive reprint and your predicament with regards to warranty
anyone parts wise worth their salt or service will be able to get you the info to be honest so perservere
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
As for the repair yes they will work on it to verify the parts at fault and if not then you will be liable for the labour but if it is faulty you pay nothing basically
having the same argument with a local VW over a noisy clutch
just check your mileage or find some record (mot) etc as i think it's 12 months/12000 miles now warranty on some stuff
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
I had a rough date but never thought to check bank statements genius
Next problem thou how can I be 1000% its the MAF don't want to be paying no labour charge
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Don't forget to allow for the company to bank the payment i.e. after a weekend etc mind too so a rough week should be enough
i guess the original box has gone as that would carry date/order info if special ordered for yourself
as for the MAF itself all i can suggest is check out the vagcom arear they may be able to help with a log/test ??
better still anyone local/mate let you test run with one ?
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
Well money went out of my account on 18th May so that should be enough for them just if they want to search for it.
Will at Performance torque ran a vagcom log and said its down on what it should be so I could do it again and see but I want to be 1000% can anything else make a MAF sensor read low but not low enough to come up as a fault on vagcom?
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
WOOP WOOP Found the invoice
Now just got to find the problem
Can anyone tell me what the MAF should be running at idle? when running?
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
is the MAF sensor 003 on VAGCOM?
Should ask Will but i'm sure he said it was about 120 on peak I think
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
Well another question
Can anyone tell me why I can't get VAG-COM to find anything
Its picks up the com port that the cable is connected but when i try and search for engine blocks picking nothing up
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
I've tried it with ignition just on and with it just on idle
But in past I have just had ignition on
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
How much is a new MAF? seems like a ball ache for a few quid :shrug:
Buy a new MAF, if it fixes it give them the old faulty one back in the packet and say it's faulty and you would like a refund please..................
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
New MAF off top of my head is £170 I think or £90 if you exchange your old one
Hence why I am a bit miffed as I have already paid £90
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
Got vag com working and came up with the following
Address 01: Engine
Controller: 6K0 906 032 AB
Component: 1.8L20VTCUPRA R 0001
Coding: 11500
Shop #: WSC 00000
2 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: 0000 1000
Address 03: ABS Brakes
Controller: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 11111
2 Faults Found:
00290 - ABS Wheel Speed Sensor: Rear Left (G46)
04-10 - Mechanical Malfunction - Intermittent
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
Which is very strange as when i did a log on the MAF it was working fine
