christ your car is beautiful!!
i think u have found a new love haha, thanks alot mate appreciated
Ever thought about this:-
The bar along the bottom of the bumper the same colour as the grills, I've seen a few on here like that and it actually look quite smart.
.G.
i said earlier i dont hold back, well i just settled a deal with an guy on ebay for a set of twin headlamps, which means woooo i cant ditch those ugly single unit ones. (after i buy new xenons) £55 bargain, off to collect, if anyones out n about al be in paisley ares
thats great...i have them on my 2003 1.2, look so much better!! ur gna have to suffer a little tho...with the twin headlamps you can only adjust the beam manually from the top of the headlight itself, the electronic adjuster inside the car doesnt work because the wiring loom for that part is different on the pre facelift. also if you have your full beams on and want to flash (using high beam) instead of the high beam comiing on with full beam it switches from full beam to high beam, i.e full beam goes off BUT if you were driving and needed to use high beam and pushed the stock outwards both work together.
that make any sense??
opinions on lip at front bumpers and wheel colour, or leave as it is......i quite like the lip and the anthrecite, ur thoughts?
u said beam alot there lol (i count 9 times lol) i dont get you, i thought it worked the same as what i have? u talking about xenons or just normal bulbs?
