What are you guys using on your 2.0 16v gtis??
Looking into getting one
Standard is on at the moment
Chris
Chris
yea lucky bugger and your bargains lol
usin the K & N panel filter does it make your car sound louder ?? like an air filter would. . . because i'm lookin to by something for my airbox or an induction kit .
ive often thought about some sort of heat sheild construction....or wing vents.
but the cost of wing vents is expensive.
well i've had one since i owned the car, it used to have a drilled airbox (but the previous owner drilled the WHOLE box lol, and then fibre glassed it closed again) and it had severe "heat lag" (due to the heat of the engine/especially the inlet) so i put a normal box back on, and works a treat!
Sorry for OT, but can you describe the symptoms of heat lag? I have the 2.0 8v, previous guy fitted a k+n cone filter thing, but when the car is hot the top end acceleration is terrible, and top speed is rather reduced.
Still looking for a standard airbox anyway
i think i mite have to construct a heat sheild for round the cone guna have a look get a nice thin sheet of metal a little set of snips a drill an it should be a good 1
