That is quite some bend from the turbo to exhaust? Will that adversely affect it in anyway?
We have a big 155mm cutting disc mounted on the bench. You can get 3/4 tight bends from 1 bend. Comes out really neat. The tightest 90 bend that ive found so far is from Jetex. Its not great as its mig'd down the middle and a tad rough.
http://www.jetex.co.uk/website/custom_parts.php?mat=Stainless&dia=3.0+inch
Its the 9th one down.
Bill, have you made a copy of that downpipe now its off the car? (i assume?)
No I use 76mm 316L stainless steel 1D & 1.5D bends.. on mine - Aalco supplied if thats of help.Bill is that the same bend as what you have used
Do a search for stainless donuts. I used part of one on my downpipe and it was a very tight bend. Got mine from the US
Here you go if your lazy http://www.deezperformance.com/CatalogDonuts.pdf
Obviously, I don't know, but by the sounds of it BDM have something like:
http://www.machinemart.co.uk/shop/p...th/power-hacksaws-bandsaws-metal-cutting-saws
hmmm donuts.. lol
are they tighter than 1D clr ? I cant make that out from the pictures
look cool tho
bill how much are the 1D 90s.
what do you think of my dp. i dont think it is much tighter than your one
they cost £25+vat each
top part of yours does'nt look bad, the lower section looked a little cut/shut
is this one the same size as the 1D you have
im not happy with the lower section. but trying to do it by yourself its hard and i only had 90s i think i need to get two 45s to get it past the propshaft
