Turbosmart Supersonic DV
Nimshoi1
Hi All,
I have a 1.8T Ibiza Cupra running Jabba custom chip, cat back exhaust, BMC induction.
Would i be wise to run a Turbosmart Supersonic DV or am i asking for trouble?
Looking for a bit more whoosh noise but not at the expense of the reliability i have.
Nimshoi:funk:
Apr 15, 2009
2,189
Midlands
I think its the Turbosmart Kompact Dual Port you will want
Im pretty sure the Supersonic is for higher output engines??
tyrrell
89
think supersonic is fully atmos, didnt no you can run fully atmos on 1.8t`s
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
You cant run a fully almos on ours without problems(ie the supersonic)...its the turbosmart dualport you want if you want proper woshy woshy noise...if your after more scooby loud then do the coldside relocation aswell...if that isnt loud enough for you then youve no hope.
Nimshoi1
cheers guys.....food for thought.
I had an open cone on (Pipercross) but went through 3 air sensors hence change to BMC
Looks like i'll try the dual port running 50/50 split and hope for the best.
Alternatively, full re-circ but minimal noise :(
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
Pipercross filters eat maf's either jetex or green filters will be fine with no problems if you want to go the open cone route.
You will have no problems with the dual port along as you have it set up correct..
daves ibiza
i got dual port and you have got to set it up propaly
