.....any chance you could do one for me
Send me a high rez pic and I'll do you one mate
cheers pal! do you need just the one? i heard that you need 3 pics,one normal,one overexposed and one underexposed, can you do it with just the one pic?
Thanks for the comments!
I used 3 pics bracketed at +1 0 -1
Both HDR have similar values, I do not know why one will have a strong halo and not the other , probably because the first was taken with vs the light of the sky
I use a program called QTPFSGUI
your better off using an exposure range of +2 0 -2
and as for using the same settings for the hdr..each picture should vary
what's the process if you've only got the 1 image then?
Use photoshop to create 3+ photos at different settings, then import into photomatrix?
