yeh i got some cupra ones last week, it was £17 for the pair inc VAT, i just need to know if they fit my 1.2 before i pull my car to bits
The only cars that the definately fit are the Sport, FR and Cupra models.
If you look at the subframe that the wishbone mounts in to - you can see the bush from the back of the subframe.
You should be able to measure the diameter of the bush from there.
Also make sure that the wishbone has a hexagon shaped end to it.
To fit them you will need the correct tool OR you will need to create a tool from large washers and threaded rod. pulling the old ones out isn't too bad because the case is plastic - but pushing the new ones in is a bitch to do cos the case is metal.
MAKE SURE YOU HAVE THE WHEEL ALIGNMENT SET CORRECTLY AFTER DOING THIS JOB.
Some people have taken the subframes off to fit them - If you go this way it would be worth deciding if you want to uprate the anti-roll bar at the same time so you only need wheel alignment doing once.
