Dash panel light
richypanic
Seat Cordoba 2.0 16v SX
Nov 8, 2008
151
Aldershot, Hampshire
How easy/difficult would it be to to replace a blown (assumed) bulb in the dash of my 2.0 16v ABF? I have no light over the fuel guage which makes it all a bit too dim. I would appreciate any top tips
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
only 2 in the top so likely it just needs refitting usually
2 screws up into the top of the speedo trim surround
once trims out there a screw either side of the cluster
twist downwards and you'll see 2 blubs clipped in the top
easier if you have an adjustable column but longish magnetic screwdriver is a plus to use too
j.cavo
8 valves of pure power
Aug 6, 2009
229
Liverpool
Have you managed to change the bulbs on your dash?
one of mine blown 2 over the speedo!
Im assuming that the bulbs are just white and there is a red film in the cluster?
what about LED bulbs?? would they work?
id just pinch some from da scrapy
