B3LSY
proper bit of kit then what sort of power will this put out when finished?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
that looks pure ****!! what turbo is that? and how much for a oil cooler bill?
i dont know.. liam supplied it.. RobDon bought it originally.. receipt for the oil cooler for £48 in the box.. plus hoses and thermostatic sandwich plate which I have'nt seen paperwork for.
13 row
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
no option on space.. it kinda fits.. where it does as there is zero spare..
engine mounts mandatory to stop it floppign about fore and aft..
its going to be lively.
assembly next, once engine mount arrive, then the fiddly bits n bobs, then mapping..
its getting there. on the home stretch now. welding & fabrication is nigh on complete, just the intake to do when it it goes back on.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
nope.. frggin things did'nt turn up as expected, nor today. got to be tomorrow now surely..
then reassembly then woohoo
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Bill the hard piped induction.
Is this SS or Aluminium?
How did you choose the size of this?
I'm looking to build the same for my LCR and had planned to use the MAP pipe and FMIC OD's as a guide. This will give me 63mm OD which is the same as you have in this project but mine will never be near this BHP.
Will this size of pipe give me any problems?
BTW I'll always use the OEM LCR throttle body
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Barnsley's and Bill's thread, but - 63mm matches turbo outlet and TB, plus intercooler sizes nicely, plus 63m is the only practical choice, the next available size down is too small.
From the pics, Bill's done it in Stainless. It's easier to get mandrel bends in stainless, and it's easier to weld and to otherwise work with, although it is a bitch to cut and weighs a ton.
If you had aluminium, you would HAVE to beads the ends, IMHO, whereas with stainless you can just about get away with it, which is good because beading stainless is a royal pain. You could always lay a bead of weld.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
charge pipework from me is alloy 63mm.. and bead rolled.. not stainless.
same goes for TIP, it is also alloy. 75mm to match turbo inlet & MAF tube.
tbody is an R32 75mm one
and the mounts arrived this morning!!! woohoo!
my ibiza runs 63mm pipe also and >600bhp, but I am considering changing to 75mm pipework and deeper fmic at some point.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
aye, will try to do some tonight..
devils own kits finally arrived also so got a shed load of packing & wrapping to do also..
all arrives at once or not at all :doh:
