Hi All,
I'm having a few issues with my car especially in third gear (sometimes all gears) at around 3500-4000RPM.
Recently I've had the following mods installed to my car, and I cant pinpoint exactly what the cause is and I'm hoping that someone can help.
Recently I've had the following installed - Place on the car.
Green Cotton Filter
Forge TIP 2nd hand
Forge 007P
Remap
The cotton filter was on before the Remap+TIP+007P and the car didn't have this problem.
I then took the car for a remap at a local re-mapper
(Who've got good reviews from all the VAG Folk in the area)
Whilst there he fitted the Forge TIP + 007P
Before fitting i noticed there was an oily... greasy substance in the TIP however no more so than the TIP that came off the car (The factory fitted one) So I can only assume this oily residue is kind of expected?
Ok so I drove home through constant traffic so I didnt get to test the car.
The first chance I had was a few days later and it started hesitating in that rough area of 3500-4000 rpm
Third gear is the best example @ 2000 rpm I can put my foot all the way to the floor
(I dont normally do this btw)
2500-2600rpm I get a nice surge of power as the turbo comes in, Puts me into the back of my seat. This continues to around 3400+ (around that area) and then Power Drops (Like its non Turbo) boost goes on, off on off on and then feels like (Possibly) 3/4 boost all the way to the end of the rev range un-interrupted.
Any ideas?
The fella ran a diagnostics and said my MAF is showing strange readings and that its pulling in 9grams of air instead of 4 grams at idle? Or something similar.
Anything else it could be and any way of checking?
I've booked the car in as its under warranty to have the MAF replaced and said that someone ran diagnostics on it and that the MAF is faulty.
However I don't want to be lumped with a bill if its not that - that's at fault?
Green Cotton Filter
Forge TIP 2nd hand
Forge 007P
Remap
Any ideas?
