FR TDi Remap?
OggTDIFR
Where's p torque located? Every tuner is Scotland is shite![:@] (wont mention any names but I've been to 3 of them)
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
hahaha...just got my seat sport stickers so they add a few horses!
when you say smoothed air intake? i got the pd160...then clipped a bit off the actually adaptor bit...that what you have done?
i have removed the dust flap and smoothed the area. (i was very bord and felt the need to mod:lol:)
techathy
^^ my name, my thought >>
Jul 9, 2009
115
Cambridge
clutch is good to 300lbs...but seen people with more and still been fine, its more about how you drive it!
im pretty gentle with mine and wait till im up in the rev range before pushing it..usually about 2500-3000
Clutch slip comes from 2 things. One is that the engine generates torque levels which simply over whelming the clutch leading to sustained slipping say full throttle up hill, this is usually at a much higher level than the maximum torque level. The torque limit is usually set at a level that when you floor the throttle & a turbo, or super-charger, goes on-boost instantly the sudden 'impact' of the torque spike can be held. With that type of spike it can easily rip the two friction surfaces apart, this is seen by a momentary slip when you suddenly floor the throttle & usually happens at higher rpm when the turbo is producing elevated pressure on a cruising throttle & the throttle is suddenly floored.
If you suddenly floored it quite high up the rpm like that you may be putting more stress on the clutch than giving it some beans at peek torque when the turbo is still a little lethargic when spooling up.
bluepassion
the company from the golf forum have just mapped my fabia vrs to 170bhp and 282 ft lb and i just cant stay out of the car now bargain £200
boxr007
hi sport rider,
is the power smooth throughout the rev range? i am looking to get my PD150 mapped and i dont want a the power to come as one big lump as with some tuning companies...
Thanks mate.
antnee
hi sport rider,
Thanks mate.
don't get a custom map from the main company talked about in this thread then
Bigbhp18t
Not sure where you are but for the North try RS Tuning in Leeds or Awesome GTi in Manchester.
Edit, for the people that have had maps from P Torque, have you had it rolling roaded anywhere else?
I was at R- Tech perforamnce last week and there was a Cupra 150PD with a P-Torque remap there having a rear ARB fitted, before my project car went on there dyno the Cupra was ran up and made around 180bhp 300lbft. A good result but 30lbft less than a past run on a Dimsport inertia only rolling road.
Ben
Justa
261
Derby
I've recently had an Oscarli map - done by Richard Washbrook himself !
Very pleased with it so far - nice and smooth but noticeably quicker
Should be somewhere around 170bhp and 280 lb's of torque but not had it on a RR (for what its worth as they all read differently)
teepee4bh
Returning old timer
Apr 19, 2009
203
Durham
hi sport rider,
Thanks mate.
i've got an upsolute map with peak torque tweaked back to make power delivery more useable. I don't like clutch shudder and wanted it to be smoother as the GF uses it most days. She's quite heavy footed and i didn't fancy having to put a clutch in it as a consequence.
She complains now that in wet it's an animal.
She doesn't like driving the beemer in wet. Doesn't trust it.
P-torque.co.uk
1,075
Wolverhampton
www.p-torque.co.uk
Hi
Here a dyno run carried out on a 130PD with P-Torque remap from another dyno...
If you search you find loads from dyno days at various companies
OggTDIFR
How do you guys rate Dimsports maps? I can get a custom rolling road tune with full diagnostics for £365 with before and after power runs.
antnee
Im sure Ive seen a Fabia VRs hybrid KKK mapped by you which had a similar dip (may have been bigger!)
