Found a pic of the exhaust:
Running in is all done now. Drives really well and no issues with the 80mm tb so far. Exhaust sound really nice, not load when just cruising, but tells you its there when you boot it. Now running 3 degs camber at the front with extra caster. Handles superb, but i think i can get better with a few more tweeks on the coilovers. Im still waiting for the carbon trim pannel to then fit the gauges, but ive temp fitted them in the old pannel for now. Got a spare headlight at work to cut up and use as a direct air feed
I will get some more pics of the inside in a bit.
I need someone to test something for me. My sec water pump doesnt work, well the pump does when 12volts is supplied straight from the battery, but no voltage from the fan control unit. There is voltage coming from the control unit, but as soon as the plug it fitted it dies to 0volts. Earths are fine and there are no breaks in the wires. Im thinking that its because im not running the ac control pannel in the dash and no stereo either. Can someone unplug their pannel and stereo and see if the pump still works or not. Pref someone with ac removed.
Cheers, Alex
Oh, had this in last week for some work. I enjoyed the test drive!!!
