what fuel do you put in the Cupra, do you go for standard 95 or V Power ? and does it make that much difference ?
I've been using Tesco 99 exclusively so this sounds a little worrying... don't suppose you have a link? All the stuff I've read seems to rave about the Tesco 99 stuff.used to use tesco 99 , but read about it messing up ur valves , so changed to v power and she is running better than ever !
so in other words 95 will be fine, if you cannot really notice the difference is it really worth using ? I never notice any difference between shell diesel and v power diesel, well perhaps slightly less smoke.
its just stuff i have read on different forums , if i come across it again i will post up.
its a lot to do with people using see grass to clean their valves , because tesco uses a lot of additives , which dont clean like v power or bp ulitmate
try 2 tankfulls of v power and you wont go back
V-Power is 99 ron. Sainsbury's super is 97 along with Esso Super, BP Ultimate etc. The only two products I buy is V-Power or Tesco Super
