Just make sure you run the power cable down the opposite side to the RCA cables
Do you have a Sub pre out or have you got a low pass filter on the amp?
Or have you got both?
Where are you putting the amp?
Ive got Low Pass Filter and High Pass Filter built into the amp, crossover slope LPF/FULL/HPF , remote bass control, gain control and its 2ohm stable, so i can i think, wire it up to 2 Subs
All I need is some decent speaker wire to connect the Sub to the Amp. Any suggestions on that?
Also, mounting? i was going to have the sub facing out (towards the back of the car), in the right forward corner(nearest to the seats on the right side of the boot), and mount the amp above it, on the back of the rear seat. Sound okay?
Also, the amp has a remote start, does that mean that aswell as the RCA cables, you wire the remote wire to the headunit, so the amp only powers up when the headunit is turned on?
Thats my only concern so far, that and getting the cable into the cabin, from the battery, and where to mount the fuse, and the ground.......
