so would just need lcr shocks willie, then an uprated front arb.... strait fit then??
no wishbones needed etc??
AFAIK James. Damien at DPM should be able to clear this up for you as they will see lots of theseso would just need lcr shocks willie, then an uprated front arb.... strait fit then??
Really???If you fit LCR shocks then you could fit the LCR ARB but in all honesty I'd just fit an uprated ARB made for your car.
Damian @ DPM Performance
'I think' doesn't really reassure us much Damien.I think you'll notice just as much diiference from just uprating the ARB, there's plenty available as well for the LC.
Well TBH I don't think you will get the same results.It's personal opinion though Willie and personally I think that starting off with a standard LC and putting LCR front shocks on just so you can fit the LCR front ARB is an expensive way of getting the same effect as just fitting an uprated ARB suited to the LC.
Don't get me wrong, the standard setup on the LCR is better then then standard setup on the LC no questions asked, but, I personally think you can get the suspension just as good and even better by getting uprated parts made for the LC.
i may have overlooked the answer but is cost an issue in this question
oh and to the original question, Weitecs are great, just fitted them and they're really good
4 Wheel alignment but without the camber due to this being a PITA but possibleHow was the geometry set on the LC Willie?
