Well after develeping a scratch in my passenger side rear door thanks to somebody i managed to grab Ben from Rubbish Boys at weekend to get his opinion, he advised it couldn't be polished out but provided me with the following useful bit of info.
"What I would do is try is to clean the scratch out with solvent. e.g. panel wipe, IPA or white spirit if nothing else available.
Then using a cocktail stick or 00000 model brush, lay some colour into the scratch. Don't try and build it up, you just want to make sure it is has covered any primer and left an even coat. Let that dry for a while.
Then, again with a cocktail stick/brush , build up some clear lacquer. Do a coat let it dry and then do another. You want to try and keep it in the scratch, let it build up slightly proud of the surrounding area but try to keep it off the surrounding area if that makes sense.
Leave it to dry for a week or so, it will probably shrink back a bit in that time.
Now the risky bit, you need to get rid of the high spots of new paint and blend it to the old. So gently wet sand the new paint with some 2000 grit paper and as the area gets smooth, you want to blend out into the old paint a little bit, but go very steady and gently. You don't want to end up with sanding grooves or go through the existing paint. I would then very gently sand with some 4000 grit to get a better finish.
Now ideally you would polish this area with a compound and a machine polisher. If you are going to do it by hand, it should be do-able but you may need to hit it a couple of times with the compound. Follow up with a finer finishing polish to get rid of marring from the compound."
Just for information purposes, the following polishes/compounds were recommended to me that should sort a scratch
http://www.carnaubawaxshop.co.uk/sho...product_id=172
http://www.carnaubawaxshop.co.uk/sho...?product_id=76
Thanks to Ben for the above.![Clap :clap: :clap:](/forums/styles/seatcupra/oldforumsmileys/clap.gif)
