I did mine at the weekend, very quick and easy job!
When you did yours Mr Bigglesworth did your sensor look like mine (nothing between the two metal prongs. Pic is on Post 12) because i still dont know if thats right Thanks.
Hi mate, mines looks exactly like yours, so don't worry!
what size are the security torx?
Cleaned mine the other day. There are two types of secuitry Torx bits - sharper pointed ones (type that hold the headlight in) and the more rounded ones that hold the MAF in.
I tried three different ones before finding the right type. The are made my Laser and I picked them up from my local car parts place - think Halfords do Laser as well.
Pretty sure it was a T27 - can check tonight if you want?
Ok Is your car running fine then? Cause mine aint boosting properly above 4k rpm, also i thought there is supposed to be some kind of thin wire or resistor between the metal prongs on maf sensor. Hopefully there aint so i can rule the maf out then?
just cleaned my AIT sensor it was thifthy! oil all over it, so i looked at the TB also dirty, so i gave it a wipe clean. Not sure if its supposed to gather oil but i guess after 60k its inevitable. The only reason why im cleaning these things is because of poor mpg even when driving like a gran. Could anyone shed some light on my above post thanks
Did cleaning the AIT and Maf cure poor MPG?? im going through the same problems right now
so you cant clean it with carb cleaner cos i clean most of my bits on the car with that
Not sure about carb cleaner but rubbing alchohol is highly recommended.
sorry to thread steal
was wondeirng how you cleaned the sensor? did you just spray the alcohol on then let it dry out?
cheers bud
cheers bud
