Made it myself used self sealing hose take offs 25mm for the dv and 8mm for the N75 abit fiddly but works had no problems with it so far.
http://www.merlinmotorsport.co.uk/index.php?cPath=2661
Thanks for the link neil, can;t wait to fit mine now
if you use them universal intercoolerpipes where do you put the intercooler sensor
t,I used the map sensor tube from Forge,
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=190101&product=FMMAPT
Sorry to hear that Bazzle Hope you get it sorted soon.
Neil> What size hosing did you use mate for that 90 degree bend (to the right hand side of the rocker cover?) And also the latter part of the brake servo pipe-manifold connection?
I used a 13mm 90 degree for the brake servo.
The crank case breather is a 19mm 90 degree.
See phil's faq thread on hoses: http://www.seatcupra.net/forums/showpost.php?p=1358522&postcount=9
What intercooler you running bazzle?
