Hi All,
A noise has recently appeared on my car, as the turbo spins up and all the torque starts to be produced. I've had it in the garage and they have found out that the engine is moving about quite alot (more than normal). They have advised that the noise is because the engine is rubbing/knocking against other parts around it and the soluition is to replace the engine mounts. The garage advised that if I replaced the old ones with new standard Seat ones they probably wouldn't last very long due to my car having been remapped.
The garage also explained that uprating the engine mounts on a diesel can make the car have excessive viberation which some people can find they can't live with.
If anyone is able to offer any advice, especially if you've uprated yours, that would be great as I'm stuck on what to do next.
Cheers,
Martin
Cheers,
Martin
