just because the engine light doesn't come on doesn't mean there's no error codes logged. if you did a scan with vag-com you'd probably find something along the lines of
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
what causes this I don't really know, but it's been suggested to me that a sticky VNT mechanism could be likely
positive deviation of pressure means the ECU is detecting an overboost.. dont worry as i said this isnt because the map has too much boost for the ECU to like, but that the map has too much boost for the standard hoses and they collapse at peak boost..
what is a VNT mechanish please?what causes this I don't really know, but it's been suggested to me that a sticky VNT mechanism could be likely
Yeh that worked for me.
Didn't need to do all the hoses, I just changed the final 90degree bend where it connects to the egr. Although I suppose it will depends which is ur weakest hose.
....the map has too much boost for the standard hoses and they collapse at peak boost..
