Limp mode
nikstar
80
Hope someone can help,
Right its an ibiza 1.9tdi (130) been remapped by local tuning company. When giving the car some beans it goes into limp mode but does not put engine manegment light on, so no codes recorded?
Any one got any ideas?
andypandypoos
Rodeo Monkey
Feb 14, 2009
319
Cowley, Oxford
just because the engine light doesn't come on doesn't mean there's no error codes logged. if you did a scan with vag-com you'd probably find something along the lines of
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
what causes this I don't really know, but it's been suggested to me that a sticky VNT mechanism could be likely
ultrasound
my pd100 used to do this after i had it remapped.. it happened whenever you reached the top of the revs in 5th gear..
the error code was saying overboost (if i remember rightly it was the code posted by andy above) which was obviously caused by the standard hoses collapsing (or opening up) at the high boost levels..
i fitted a new performance silicon hose between the hard plastic pipe and the EGR valve (90 degree bend) and it doesnt do it now.. happy days!
nikstar
80
There wernt any codes last time i check but it done it last nite so al put vag com when av got 5 mins!!
nikstar
80
Yeah thats what the code is, well top one at least. but car only started doing it after the remap??
ultrasound
positive deviation of pressure means the ECU is detecting an overboost.. dont worry as i said this isnt because the map has too much boost for the ECU to like, but that the map has too much boost for the standard hoses and they collapse at peak boost..
I recently had a remap and this also happens to me, strange thing is i turn engine off and on again and i get full boost then. If i turn the engine off and leave it for a while the low boost problem sometimes comes back.
So i take it the best thing to do is upgrade standard hoses?
ultrasound
Yeh that worked for me.
Didn't need to do all the hoses, I just changed the final 90degree bend where it connects to the egr. Although I suppose it will depends which is ur weakest hose.
Neil82
546
Visit site
Where did you get the pipe from? Did you just fit another standard one?
Neil
muddyboots
Still hanging around
Oct 16, 2002
5,739
....the map has too much boost for the standard hoses and they collapse at peak boost..
Hoses don't collapse when they're pressurised inside...
...and if they let go or leaked under pressure, you'd lose boost and get a negative deviation error, not a positive one.
I'd say the probable causes are either turbo related (eg sticky VNT) or remap related (too much boost at high RPM).
ultrasound
it solved the problem for me, and that was the error I was getting on VAGCOM everytime it happened..
Im not sure if the hose was expanding too far and letting extra air in, or collapsing thus reducing the bore and creating more pressure in the turbo..
I got my new 90degree hose from 'Demon Motorsport' - its an ebay store but im not allowed to post links on SCN yet...
chispadete
or intake temps got to hot for boost requested meaning top speed is goes into limp mode. a better intercooler can help on a generi map this shouldnt happen however
cupratdianth
so it worth just upgrading all the standard hoses anyway? and if so wheres the best place to get them for tdi?
