MK3 Cupra Part Numbers
alix
53
part number for air con pump/compressor
anyone know the number-made by sanden?
thanks
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
thanks
Sanden Code SD-7-V16 is the most common i believe but will depends on year and model and chassis as to what Vag code it is
alix
53
Sanden part. no
Thanks mate, I have a mk3 tdi ibiza 110 on a 51 plate, am looking at a sanden pump part no. r134a 1jo 820 803 k from an 02 ibiza 1.4 petrol-reckon it will be the same?
Nov 2, 2004
9,335
South Wales
Master Cylinder 6K2721401A £46.90 + VAT
Slave Cylinder 1J0721261J £31.05 + VAT
Door clips push fit things to hold the door cards on 6K0 868 243 C -£1.22
Arch Liner - 6K0 809 961 D B41 - arch liner 19.71
1J0 927 804 - ABS speed sensor 42.17
N 014 740 4 - allen bolt for above. 0.09
6k3 867 109 b01c - Escutcheon - Passenger side door pin surround -
ebo007
185
Dundee, Scotland
Looking for some assistance before i go mad.
i need a reverse gear switch that sits on top of gearbox. Having no end of trouble with Arnold Clark Seat in Edinburgh :censored:
They gave me the incorrect switch 1st time. I need a screw in one. Apparently there is 2 listed and the guy wants me to take the old one off and give him the number off it. As the car is still required for dailly use i told him where to go and order 2 of them and i will check which one is the correct one. He has advised me he can do it but i'd have to pay for both as they are non returnable items...??? :doh:
Is it just me or is this guy a muppet - why would i pay for 2 switches when i only need 1?
So if anyone else has replaced theres and know the part number it would be greatly appriciated.?
Had a search in this thread but cant see it. Apologies if I have missed it...
n15mgd
well if theres two listed and you've tried one which is wrong then if theres only two correct then it must be the other?
ebo007
185
Dundee, Scotland
there are 2 screw in one's - i haven't had any of them as the 1st one i got was totally the wrong kind. So I have 2 to choose from and the wont send them unless i pay for bth of them and they are non returnable. F**king joke :banned:
vetec
drivers side window switches 6X0 959 855 B - £14.32 each
hi,do you know where can i buy the switch at this price as my dealer wants £27 for one. in black with one touch for my ibiza 1.9 110 sport on a 51 reg ;)
mary jane
anyone know the part number for the 20vt engine cover on the Cupra R? i couldnt find it on VAGCAT.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
with the car details i can have a good look but why not unscrew it, write down the number and screw it back in ?
might even see it on the side if ya lucky
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
if you can login ok it's this one as usual Etka etc uses some diagrams that do leave a lot to be desired
http://www.vagcat.com/epc/cat/se/LE/2004/268/49/4749418/
(??) brackets either side of a number means the diagram is only depicting a relevant image and not actually showing the part number listed
cover for engine compartment / 1.8ltr.
cover for engine compartment / 1.8ltr. / AMK,BAM
mary jane
Cupra Ibiza engine cover part number request
ok, ive concluded its the Cupra Ibiza not the R engine cover!
now all i need is the part number...first to tell me gets a cookie!!!!
Razor
Inked Up Nation
Oct 12, 2008
830
Outside Belfast
www.bebo.com
hey sorry to bring an old thread up but does anyone know or can get me the part number for the front engine mount for the mk3 cupra? not the rubber part the metal part, as i thaught id orderd it from seat but it turned out they got me the rubber part, any info would be great, thanks alot
Is the engine mount number the same for the 1.4 ??
Anyone please
