Which NGK spark plugs????
GregLCR04
99 Ron Please!!!!
Oct 31, 2006
115
Dumbarton, Scotland
Have done a search looking for advice on which NGK spark plugs to use. I'm currently using NGK PFR6Q which I understand are the standard ones. I have recently had my car stage 1 remapped and have heard its better to use colder plugs on mapped cars??
I've always used NGK plugs and can't praise them enough. I was just unsure which one to go for, its between the platinum one i'm using just now or go for iridium ones. :think:
If i decide to go for iridium plugs should I go for the BKR6EIX or the colder BKR7EIX ones. Any help and advice would be appeciated.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
same here for NGK won't use anything else, If you believe what the reps and promos have to say then the difference platinum/iridium is longer life from the differing metal material
as a guide
normal 20k miles
platinum 40k miles
iridium 60k miles
saying that though it's not always 'just' about mileage as the materials get harder they are less prone to blob/melt/detonate etc but a 'NGK 7' (colder) plug always seems to be reccomended once you start pushing some boost and a lot of people seem to like the Denso Iridium as an alternative but I would check out the big turbo tuning section - plenty of threads about on Denso and alternatives etc there
Mark300zx
1,458
8
Surrey/SW London
There is another theory that copper plugs are the way forward on turbo cars. The reason for this is if a cylinder runs lean and hot, the plugs starts to melt and the spark stops being produced.
Platinum and iridium keep on producing a spark under adverse conditions and then engine components fail.
