split pipe
drue1
193
kent
I took my engine cover off and the other small engine cover to see if i could find any loose wires for my temp gauge.Ive found a split pipe........I cant take it off to show a photo as one end has one of them clips you cant take off.Anyway the pipe has loads of oil crud inside it so im thinking its an oil breather.car runs fine with no fault codes as i had the car remapped friday afternoon at amd.does anyone have a blown up picture of the engine pipework please with part numbers
thanks
D.K
LCR 225
Oct 24, 2007
6,408
se london
There is a breather tahat split's on the Cupra's, What size is the pipe ? might be better off buying a length of silicon from Forge or Ebay.
Aug 24, 2007
800
I'm betting its one of the red ones:
either that or one of the pipes under the manifold :)
