Hi,
I’ve read a few threads about dodgy indicators, dodgy stalks etc but I can’t find one to best fit my problem.
The bulb warning light is on and one of the rear indicators is out and the indicator ticks fast, no problem with that.
But when I put the alarm on the indicator flashes so I know it’s not the bulb. Also it’s intermittent so on another journey the bulb warning light is off and the indicator ticks normally.
The front indicators work so don’t think it is the stalk.
I recently replaced my rear brake light and thought I might as well do them both. The indicator that is playing up is on the side with the good brake light and seen as both brake lights work I’m confident it’s not the wiring.
What I’m wondering is could it be the connection within the unit ? When you replace the brake light you pull it out of the unit and the indicator sits behind, I’m assuming the small metal clips are the contacts as the wiring plugs into the brake light section… but then again if it was the connection surely the indicator wouldn’t flash with the alarm ? Confused !!!
Any advice appreciated, yesterday morning they weren’t working, on the way home they were and this morning they weren’t !!
