Boost Gauge No BUZZ
Jun 7, 2006
2,983
Norfolk, Norwich
Hello
Just ordered my Boost Gauge. got me an Auto gauge smoked face 270 degree jobbie. smoked face and was the closest match the the dash i could find.
it comes with a fitting kit but i have seen that i need a No Buzz part from reading on here.
where do i get an Inline No Buzz part from?
Lee
andycupra
status subject to change
yea but thats an T Piece. i am after an inline one. :)
Lee
and how do you intend to fit this guage? - i suggest that you will require a T piece at some point.
Or as said in the threads ive linked to, blank off the T piece and fit it as an inline part. - although some may say you may as well resrict the pipe with something cheaper, such as a cable tie.
i think the Autogauge ones come with a restrictor already... is it a little brass bit in teh end of the t piece?
Lee
the little brass bit you refer to is likely to be the part you should have used as part of the way the pipe is attached to the gauge.
2,983
Norfolk, Norwich
i will be getting a jabba egr pipe so i dont think ill need the T piece and that will be my feed from the boost pipe.
if the t piece supplied has the brass bit in ill fit it. if not i need to find one that is an inline one :)
Lee
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
You could still use the T and just blank off the end your not using, that way you still have the restrictor..
