Could you only drill the holes and do nothing else to the box to achieve a louder sound with no down sides?
if you just stick in a panel filter, dnot bother smoothing or drilling the airbox will you notice any differance?
The O/E on e is only about 1.5" x 2.5", so you will get a lot more air with a 3" feed pipei Thought it was a 3" pipe on the lcr anyway? does smoothing the airbox actuly make a difference?
how come it doesn't sound as good as the airbox did on the Fr![]()
If you have a cupra then you can put it down to the fog light, if you cave a Cupra R you cant brcause of the side mount intercoolerHave you lot put your large air feed down to the original inatke at the front of the engine bay of have you taken that out as well and put it down behind bumper?
