how many bhp has your cupra 180 got??
vee_dub_modder
Volkswagen racing tech-pt
Feb 19, 2008
406
Midlands
Have you got the part numbers?? I found a nice kit with floating rotors but some nice shiny porsch 996 ones would be unber cool ;)
hoping to be ablt to pick a pair up for under £400 off fleabay
SeatR
399
Norway, Bergen
hey guys, i recently bhought a 180bhp leon and want to sort out all the easyest mods before i get it remapped, to get the most power out of it. thinking something like 230bhp.
What mods to shop?
4bar fpr
3" maf house?
exhaust
fmic
i got a set of 225 BAM injectors, do these fit and can it be run along with a k03s?
jamiebennett81
What mods to shop?
4bar fpr
3" maf house?
exhaust
fmic
you dont need to change the MAF housing, FPR (dependant on mapper) or the injectors for just a stg2 k03s
injectors and MAF typically only needed to be changed when going k03 hybrid or bigger
Exhaust and FMIC is a must though
cupra_matt86
southend cruiser,not chav
May 18, 2009
102
Essex
I read that the leon 180 can go to a max of 300BHP before replacing internals and rebuilding the bottom end, mine is bout 200BHP at the moment, just waitin for my FMIC, hoses and get a remap.... hopefully i will get around 240BHP along with my other mods.
jamiebennett81
no, its 350, with a small prayer said at the same time too
cupra_matt86
May 18, 2009
102
Essex
StevieP
9
My 2002 Cupra 180 runs 222/254 with shielded cone filter, custom 3"decat/2.5" catback, stock side mount IC and custom Stage 2 remap. Still think theres a little room for improvement. Once the FMIC is fitted after new year ill get her back on the dyno and tweaked
nd-photo.nl
3,668
22
The Netherlands
www.nd-photo.nl
Im driving around with 261BHP/395Nm (or 291LB)
Mapped with BP Ultimate RON98
20130616_JD_STage2_BPUltimate_r324932 by ND-Photo.nl, on Flickr
Mapped with BP Ultimate RON98 + Bio ethanol
20130616_JD_STage2_E85_r32493 by ND-Photo.nl, on Flickr
Mods:
-3" Toyosports downpipe modded with Magnaflow 200CPI sportscat
-2.5" Cobra Resonated catback
-Custom FMIC
-Toyosports FMIC piping
-Forge 006 yellow spring + 1 shim (in BOV mode)
-Creations Motorsport coldside DV kit
-NGK BKR7E sparks
-Kendall 5W50 Fully synthetic oil
-N249/N112 mod
-SFS Big Bore TIP
-Blox Velocity Stack airfilter
-Ltec Secondairy fuel pump
-4 BAR FPR
-BAM Racing Phenolic intake spacer
-Mapped out the MAF
And then there's the uprated brakes, suspension, etc. Car is mapped by JD Engineering in Holland.
