yep, all your discs and pads need replaced
Standard diagnosis from Kwik Fit
"....your exhaust is also blowing and it cold realy do with a service. Oh i also see your MOT is due next month shall we do that while you wait?"
Im guessing it will go a lot like that!
Find a local independent where prices are much better and your less likley to have your pants pulled down
" Im afraid the the vehicle is unsafe to drive and we cant allow you to leave either"
Why dont you just have a look and see if the pads are low and discs are cracked/ big lip?
Going to put my MK4 Ibiza, 56 plate into one of these places for a free brake check.
Any advice/words on these two and which one should I use, if any?
honestly, I think that people should be shot that can't do that.
it's no harder than checking your tyres
Those pictures are like how I see after six pints.
look for a whopping great lip on the discs (I think you can see that in the pic)
and you just need to look at the pad to see what thickness is left...
squeaking when you brake can be dirty brakes, but more often the pads are about to wear right out.
