Yeah like I said a lower spring won't cause a problem but a higher one will. Yellow is designed for remap if you look at the boost levels on the forge site. Yellow will give quicker response when you lift off the throttle whereas green will be slower.yet forges actual advice is to leave it green unless you get problems. yellow isnt needed for a remapped car. green should seal fine
how can i be running the equal to the green spring on 320bhp? anything heavier would knacker my turbo
just found this..
http://www.seatcupra.net/forums/showthread.php?t=99417&referrerid=10009
