can cruise control be fitted to a ibiza cupra 02?
greg
Newbie
Aug 31, 2005
256
Always do a search mate first or you will be crucified on here!!
As your new though ill help you out ;) A new indicator stalk can be purchased from seat for 100 odd quid i think. Then you need to hardwire it in (drop me a pm with your email address and i will email you a guide) then let the ECU know it has cruise control fitted using VAG-COM (not sure on exact code needed to activate CC but a search will bring it up :D )
Hope this helps.
Greg
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
From Ross-tech/Vag-Com
Activating Cruise Control on a new ECU (DBW):
Factory fresh ECU's often come with cruise control de-activated. If this is the case, there will not be a letter "G" in the Component field of VAG-COM when connected to the Engine.
[Select]
[01 - Engine]
[Login - 11]
Enter 11463 to activate cruise control
[Do It!]
After doing this procedure, there should be a letter "G" in the Component field.
joe_thompson
41
:d
cheers guys!
that great (y) i think im gona try n get cruise control as i think it iwll help me out with fuel as its not very good at moe :(
Mat
I reckon it's a goodthing for a lot of motorway driving! I can't justify it myself TBH! Otherwise I'd have it
