help dbone mount bolt snapped into subframe
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
hi guys as above, discovered one bolt snapped and the thread is in the subframe.
struggled to get it out tbh...
hows best to deal with this
new subframe comes to mind.
whats the cost approx for these.
grrrh
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
james walker
May 24, 2007
5,121
retford notts
i guess, you drill a pilot hole into the bolt, the insert the right size tool above and turn anti clockwise to remove?
correct?
james walker
May 24, 2007
5,121
retford notts
best to heat the bolt first to soften it to make the extractor easier to get in?
whats a decent cheap ish heat gun to use, probably never use it again so....
james walker
May 24, 2007
5,121
retford notts
ok, is it best to take the kit and give to a local garage or have a bash myself on axle stands etc
very tool/mechanically minded so could probably do it
ginger prince
use the biggest size easi-out you can as they can snap, if you that happens you got a whole new world of pain!!
shame your not near milton keynes i've got a set you could have used, but there not that expensive
good luck
james walker
May 24, 2007
5,121
retford notts
Not get any metal bits?
BQ will sell a good one cheaply if you just want one, take your time and save the cash doing it yourself.
yeah got metal bits, but tbh would like to invest in a decent one to make life easier....
what size would be best for this nut guys...
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
James, if your buying easy outs buy the square ones, have had much better results with these than the round ones. Contrary to the above use the smallest size first then move up if you have to. theres not much torque on these bolts so should be easy to take out.
james walker
May 24, 2007
5,121
retford notts
will do, the bolt is loose, just cant get to it to remove due to the housing it sits in...
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
If its loose anyway just try drilling it and it will probably spin in and drop into the sub frame.
Cant you get at it with long nose pliers or a small cold chisle
