Does your Cupra smoke much out the exhaust?
P-torque.co.uk
1,075
Wolverhampton
www.p-torque.co.uk
I THINK the error code on vagcom might actually have been referring to the pre-cat lambda as it mentioned heat. So maybe that needs replacing
I'll wait until I take it back to P-torque and I'm sure they can sort it as said. :) I've actually thought mpg has been quite good but if it will turn out to be even better then I look forward to it :D
Hi!
Regarding the lambda, I said we could map the sensor out which would mean no issues ;)
