I did think of this when I removed mine but there isn't much 'meat' left in the swing arm after doing this, only way would be to extend the arms about 25mm then you could use the slots
DISCO!!!!!i am going to try different tyres next time JS, as i am curious as to see if i notice a difference. i do admit the pirelli's are poor in the wet, but pushing it in the wet on public roads your asking for trouble in my opinion however good your tyres may be.![]()
DISCO!!!!!
Its not all about driving fast in the wet, its also about safety in the wet.
Pat, get the front ARB done ASAP, there far far more grip to be had still
I must be the only one here that thinks there ok or maybe im just not driving the leon hard enough!!!
Basically the side walls of the Pzero are quite weak in construction and particularly at motorway speeds the tyre distorts, the area of tyre in contact with the road in reduces and you run on the centre of the tread pattern. This is why the centre wears out first.
How can they be so bad when they are used in motorsport like WRC and the likes???? seems crazy that these teams are using a tyre that is said to be so bad by so many people???I must be the only one here that thinks there ok or maybe im just not driving the leon hard enough!!!
i thought there were two versions thoughweren't the people who had this problem running the normall p-zero's, whereas the leon needs the extra load version due to it being such a heavy car!
As above I've got a mate with a Mondeo ST220, I advised him to get the GSD3's, he hated them but totally loved the Pirelli P Zero's
How many tellings do you guys need?? lol
Fit these and forget about tyres being your weak point in you car, then start looking at the other weaknesses like ARB's and strutt braces
Got a upper strut brace. That helps allot!!
